Proper use of SaveAsFlatDXF
I'm writing a program to take .psm files and output .dxf files for the turret punch. I started with some code I found here. It seems to be working fine except I'm having trouble understanding how to control the Edge. I want them oriented so that the long edge is horizontal and the short edge is verticle. Please help.
ForEachMe.objModel In objModels
        If objModel.Name = "Design Model"Then
          objBody = objModel.Body
          objShells = objBody.Shells
          objShell = objShells.Item(0)
          objFaces = objShell.Faces
          ForEachMe.objFace In objFaces
            If objFace.Area > ddMaxSurf Then
              ddMaxSurf = objFace.Area
              objBiggestFace = objFace
            EndIf
          Next
          objEdges = objBiggestFace.Edges
          ForEachMe.objEdge In objEdges
            objEdgeUsed = objEdge
            objVertex = objEdgeUsed.StartVertex
            If objVertex IsNothingThen
              'Keep going.
            Else
              Exit For
            EndIf
          Next
          'Dim ddVertex As Double = 0
          'For Each Me.objEdge In objEdges
          '  If (System.Math.Abs(objEdge.EndVertex.ToString - objEdge.StartVertex.ToString) > ddVertex) Then
          '    objLongestEdge = objEdge
          '  End If
          'Next
          'objEdge = objEdges.Item(1)  '0 for now, may change this later.
          'objVertex = objEdge.StartVertex
          'objEdge = objVertex.Edges
        EndIf
      Next
Posted by: Terry Tyson
Post date: 9/23/2010 3:10:29 AM
RE: Proper use of SaveAsFlatDXF
I copy here a full code I wrote in Excel.
The code take a file path for a group of selected cells and create a dxf.
Any doub please ask me.
Sub dxf()
Dim objApp As Object
Dim Celda As Object
Dim i As Integer
Dim HayRepetidos As Boolean
Dim ChapaEspecial As Boolean
Dim SinVertice As Boolean
Dim ChapaMec As Boolean
Dim Verifica As Boolean
Dim HayExistentes As Boolean
'Dim ObjSEF As SolidEdgeFramework.Window
Dim ExisteDXF As Boolean
Dim ExisteArc As Boolean
Dim HayArcInexistentes As Boolean
Dim NombreDXF As String
ExisteArc = False
ExisteDXF = False
HayExistentes = False
HayArcInexistentes = False
SinVertice = False
ChapaMec = False
ChapaEspecial = False
HayRepetidos = False
    'Verifica que el solid edge este activo
    On Error Resume Next
    Set objApp = GetObject(, "SolidEdge.Application")
    If Err.Number = 429 Then
        'Set objApp = CreateObject("SolidEdge.Application")
        MsgBox Prompt:="Debe abrir el Solid Edge"
        GoTo fin
    End If
    On Error GoTo 0
Range(Selection.Address).Select
For Each Celda In Range(Selection.Address)
    Application.StatusBar = "Procesando   " & Trim$(Celda.Value)
    Celda.Interior.ColorIndex = 8
    Verifica = False
    ExisteDXF = False
    ExisteArc = False
    'Marca los archivo ya procesados que se intentan volver a procesar
    For i = 0 To Indice
        If Ultima(i) = Celda.Value Then
        Verifica = True
        Celda.Interior.ColorIndex = 45
        End If
    Next i
    NombreDXF = Mid$(Trim(Celda.Value), 1, Len(Trim$(Celda.Value)) - 4) + ".dxf"
    If frmMenu.CkBoxSobDXF.Value = False Then
        ExisteDXF = VerificaExistencia(NombreDXF)
    Else
        ExisteDXF = False
    End If
    ExisteArc = VerificaExistencia(Trim$(Celda.Value))
    If ExisteArc Then
        If Not ExisteDXF Then
            ChapaEspecial = TipoChapa(Celda.Value)
            If Not ChapaEspecial Then
                If Not Verifica Then
                    If InStr(1, LCase$(Celda.Value), ".psm") Then
                        SinVertice = GuardaComoDXF(CStr(Trim$(Celda.Value)), NombreDXF)
                        If SinVertice = True Then
                            Celda.Interior.ColorIndex = 3
                        End If
                    End If
                Else
                    HayRepetidos = True
                End If
            Else
                Celda.Interior.ColorIndex = 15
                ChapaMec = True
            End If
        Else
            HayExistentes = True
            Celda.Interior.ColorIndex = 7
        End If
    Else
        HayArcInexistentes = True
        Celda.Interior.ColorIndex = 36
    End If
    NombreDXF = ""
    'Minimiza la ventana de SolidEdge
        objApp.WindowState = 2
    On Error GoTo 0
Next Celda
Application.StatusBar = "Alertas"
If HayRepetidos Then
MsgBox ("Hay archivos resaltados en NARANJA repetidos que no se procesaron")
End If
If SinVertice Then
MsgBox ("Hay archivos resaltados en ROJO que no se pudieron procesar")
End If
If ChapaMec Then
MsgBox ("Hay archivos resaltados en GRIS que no se procesaron (son chapas mecanizadas)")
End If
If HayExistentes Then
MsgBox ("Hay archivos resaltados en VIOLETA que no se procesaron porque se encontro que ya existía un DXF")
End If
If HayArcInexistentes Then
MsgBox ("Hay archivos resaltados en AMARILLO que no se procesaron porque no se encontraron")
End If
fin:
Application.StatusBar = False
End Sub
Private Function GuardaComoDXF(ArchivoPSM As String, ArchivoDXF As String)
Dim objDoc As Object
Dim ObjCaras As Object
Dim ObjCara As Object
Dim Edge As Object
Dim Edge1 As Object
Dim Vertice As Object
Dim Vertice1 As Object
Dim ObjOp As Object
Dim Operacion As Object
Dim Faces As Variant
Dim Area As Double
Dim Area1 As Double
Dim NroCaras As Integer
Dim i As Integer
Dim Cara As Integer
Dim NroEdges As Integer
Dim StartPoint(3) As Double
Dim EndPoint(3) As Double
Dim Largo1 As Double
Dim Largo As Double
    'On Error Resume Next
        Set objDoc = objApp.Documents.Open(ArchivoPSM)
    'If Error 0 Then
    '    GuardaComoDXF = True
    '    If Not objDoc Is Nothing Then
    '        objDoc.Close False
    '    End If
    '    Exit Function
    'End If
    'On Error GoTo 0
    'Suprimer las operaciones cuyo nombre segun el nombre
    Set ObjOp = objDoc.Models.Item(1).Features
    For Each Operacion In ObjOp
        If InStr(1, LCase$(Operacion.Name), OpNombre1) 0 _
        Or InStr(1, LCase$(Operacion.Name), OpNombre2) 0 Then
            Operacion.Suppress = True
        End If
    Next Operacion
    'Comienza la rutina de guardar como dxf
    Set ObjCaras = objDoc.Models(1).Body.Shells
    NroCaras = objDoc.Models(1).Body.Shells(1).Faces.Count
    Area = 0
    For i = 0 To NroCaras
        Area1 = objDoc.Models(1).Body.Shells(1).Faces(i).Area
        If Area1 >= Area Then
            Area = Area1
            Cara = i
        End If
    Next i
    'NombreDXF = Mid$(Trim(Celda.Value), 1, Len(Trim(Celda.Value)) - 4) + ".dxf"
    Set ObjCara = objDoc.Models(1).Body.Shells(1).Faces(Cara)
    NroEdges = objDoc.Models(1).Body.Shells(1).Faces(Cara).Edges.Count
    Largo = 0
    For i = 0 To NroEdges
        Set Edge1 = objDoc.Models(1).Body.Shells(1).Faces(Cara).Edges(i)
        Set Vertice1 = objDoc.Models(1).Body.Shells(1).Faces(Cara).Edges(i).StartVertex
        Call Edge1.GetEndPoints(StartPoint, EndPoint)
        Largo1 = EdgeLong(StartPoint, EndPoint)
        If Not Vertice1 Is Nothing And Largo1 > Largo Then
            Set Vertice = Vertice1
            Set Edge = Edge1
            Largo = Largo1
        End If
    Next i
    If Not Vertice Is Nothing Then
        Call objDoc.Models.SaveAsFlatDXF(ArchivoDXF, ObjCara, Edge, Vertice)
    Else
            objDoc.Close False
        End If
        Exit Function
    End If
    'Termina la rutina de guardar como dxf
    ' Close the document without saving.
        objDoc.Close False
    End If
    Ultima(Indice) = ArchivoPSM
    Indice = Indice + 1
    frmMenu.LblContador.Caption = Indice
End Function
Private Function EdgeLong(StartPoint() As Double, EndPoint() As Double)
Dim X1, Y1, Z1 As Double
Dim X2, Y2, Z2 As Double
X1 = StartPoint(0)
Y1 = StartPoint(1)
Z1 = StartPoint(2)
X2 = EndPoint(0)
Y2 = EndPoint(1)
Z2 = EndPoint(2)
EdgeLong = Sqr((X1 - X2) ^ 2 + (Y1 - Y2) ^ 2 + (Z1 - Z2) ^ 2)
End Function
'Esta funcion determina si la chapa tiene alguna particularidad
'por la cual no se le pueda realizar un DXF
Private Function TipoChapa(Archivo As String)
'If InStr(1, LCase$(Archivo), "hm") Then
'    TipoChapa = True
'ElseIf InStr(1, LCase$(Archivo), "hp") Then
'    TipoChapa = True
'ElseIf InStr(1, LCase$(Archivo), "hr") Then
'    TipoChapa = True
'End If
    TipoChapa = False
End Function
'Verifica si el archivo DXF que se intenta crear Existe
Private Function VerificaExistencia(Archivo As String)
    Dim a As Variant
    a = Dir(Archivo)
    If a "" Then
        VerificaExistencia = True
    Else
        VerificaExistencia = False
    End If
End Function
Posted by: Mariano Spini
Post date: 10/12/2010 4:36:31 PM
