Protrusion using edges
Hi everyone,
I'm trying to make a protrusion by fitting through a series of cross sections.  First I tried to use profiles but I am working in synchronous mode so I had no luck. Now I am attempting to make use of edges (igEdgeBasedCrossSection) but I have not found enough information on how to use it. After I figure that part I know I have to make the protrusion using addLoftedProtrusion but I am not clear on what values the parameters should have.
Could anyone provide an example so I can start off?
Thanks.
Gabriela
