Pull down menus in SE V20 through ADD-Ins
HI,
I have seen Solid Edge Add-Ins for adding command buttons ( Tool Bar with buttons)  and successfully added to Solid Edge Draft so far.
I have Solid Edge V20 and i want to add Pull Down Menus instead of command buttons (Tool Bar) in draft environment.
What need to be changed in Add-In so that Pull Down Menus will be added ?
Ravi
Posted by: Ravindra Mujumdar
Post date: 6/21/2010 6:23:36 PM
RE: Pull down menus in SE V20 through ADD-Ins
I have referred almost all the stuff available on this site about AddIns.
I am not familiar with VC++ but good in VB. Is the code for Menu only available in VC++ ?
Anybody having a snippet in VB to do it.
Please post it for me.
Ravi
Post date: 6/25/2010 4:14:52 AM
