Pull part face color into draft
I have so far not been able to find any way to pull the face (or body) color of a .psm or .par into a draft.  I know you can make different faces different colors but for our purposes we paint all of the faces of a specific part one color the way they are painted on the paint line in real life.  SE knows what that color is because when i pull up 'Format' -> 'Style' -> 'Faces Style' and at the bottom select 'Styles in use' it shows only the one face color, and this is what i want to pull into a field in the draft.
Has anyone else tried to do this or found a solution?  Either with or without extra programming?  Thanks in advance for any help!
-Roscoe
Posted by: Roscoe Lehman
Post date: 4/7/2008 2:19:16 AM
