Question about features
I used to use the following to rename features in the feature tree but it no longer works.  any thoughts?
cSE.iFeatures = cSE.oPartDoc.Models.Item(1).Features.Count;
oModel.Features.Item(iFeatures).Name = "Weld Chamfer";
Bob Reinkemeyer
CAD Integration developer
Martin Sprocket and Gear Inc.
Re: Question about features
You can try this,
objModel = objPart.Models.Item(1)
objfeats = objModel.Features
objModel.Features.Item(1).name = "test"
Its working for me.
Bala
that's what I have.  It was working before I switched over to the community dll.  the error essentially says the object contains no definition for "name"
Bob Reinkemeyer
Hi, since you select the last feature in list, what is the type of this feature. Maybe it does not have a Name attribute.
JB
SE ST10
Check if you need to call Recompute at document of feature level after renaming.
just to be clear, I'm looking to rename features in the feature pathfinder in the part document.
Bob Reinkemeyer
