Read Occurrences directly from file?
Is there a way to read the Occurrences directly from an assembly file without opening Solid Edge?
Terry Tyson
Software Automation Designer
Re: Read Occurrences directly from file?
You can kick off the LinkInfoTest.exe in the Program folder. Then you can use Windows automation tools (AutomationElement) to browse the file you want and parse out the results. Something like AutomationSpy can get you the AutomationId values.
Siemens PLM Software, Inc.
Project Test Engineer (Automation)
I don't have a LinkInfoTest.exe. Probably another reason to upgrade to ST9.LinkFilesAvailable.JPG
Terry Tyson
Esteemed Contributor
If you look in the SE download or the DVD in the SDK\Advanced\Readers folder, you will find "SEreader.dll" which will allow you to get Occurences in an Assembly file without SE.  Not sure exactly how to use it but GTAC can get you more info on it.
Production: ST10 MP3
Testing: SE 2019
Ken, thanks for the solution. This looks like it is going to work perfectly. I did run into a temporary snag. Apparantly SEReader.dll is 64bit only. I had "Any CPU" selected and "Prefer 32-bit" checked. I kept getting a "Class not registered" error. Once I switched the platform to x64 it worked. Thanks for the help.
Terry Tyson
