Read design dimensions problem!
Hello Jason!
I'm having a little problem ... I hope it is short hehe
I'm trying to read all information in the design dimensions, but when I open a Traditional part, it works ok, but then I open a Part Syncronous, the error occurs "Return argument has an invalid". If by chance I open the first part Syncornous, it reads the size normally, but then to open the Part Traditionally, the error occurs again.
It seems he is the type of document stored in memory after the first and only validates that abarto
Will you help me?
Posted by: Fabio Rosa
Post date: 3/11/2009 5:06:06 AM
