Read draft files in Insight installation
I've made some modification in the Batch program (in Custom from SEV17). It wortks fine.
But when I want to select files on the Insight server, i can'see and select thenm.
Can some body help me to see the "Insight Disk"?
Thx
Posted by: Jean-Marie Cloquette
Post date: 8/2/2009 7:51:18 PM
RE: Read draft files in Insight installation
you won't be able to see SharePoint folders with the standard controls. I have written some .Net components to allow a user to browse SharePoint folders here:
http://www.codeproject.com/KB/cpp/ExpCombo.aspx
You probably won't be able to get them working with VB6 but there may be some similar controls out there for that.
Hope this helps
Calum
Posted by: Calum McLellan
Post date: 8/2/2009 9:22:02 PM
Hi Calum,
Thx.
I will modify and try it immediatly.
JM
Post date: 8/3/2009 8:12:11 AM
