Read out Interpart Structure with Revision Mangager in C++
How can I read out a solid edge structure with Interparts using revision manager or SE-API in C++.
Thanks a lot
Posted by: Abou Mimin
Post date: 1/31/2008 5:29:08 PM
RE: Read out Interpart Structure with Revision Mangager in C++
Can you reply with an interpart example? I'm trying to figure out if the interpart structure looks any different than normal links.
Posted by: Jason Newell
Post date: 2/4/2008 6:26:45 AM
