Reading "Last Saved Version" attribute from SE file
Quick question for yall, is there any way to read the Last Saved Version string from SE files without loading them into an Edge application? I've tried listing out the properties programmatically using the SE Properties API's but none that I can read seem to hold the information I need. I know SE Power Toys can list the Last Saved Version in explorer, which leads me to believe this information is available without the need for an Edge session.
Thoughts anyone?
Posted by: Jeremy Bateman
Post date: 7/9/2008 11:50:54 AM
RE: Reading "Last Saved Version" attribute from SE file
Looks like Jason has removed his FileProperties API from the downloads, but you can get an extended version from the folleowing post:
http://www.jasonnewell.net/Forums/tabid/55/forumid/1/tpage/1/view/topic/postid/831/Default.aspx
One of the last posts has a .Net 2.0 version. Let me know if you need .Net 1.1.
You can use this to read the created version and the last saved version.
Cheers
Calum
Posted by: Calum McLellan
Post date: 7/9/2008 11:57:41 AM
Perfect, that was exactly what I needed. Thank you much!
Post date: 7/9/2008 12:38:26 PM
