Refresh View
I have written a VBnet program which allows the user to modify property text on a drawing frame without having to go into the backgroubd sheet and edit text etc.
My problem / question is how do i refresh the drawing view
i have tried
objDocument.UpdatePropertyTextCacheAndDisplay()
objApplication.StartCommand(32876)
and even
AppActivate(
 "Control Panel"
SendKeys.Send(
 "{F5}"
activedocument.windows.items.update, it wont accept items, only item
is there anywhere that explains how to use solid edge spy as i would like to be able to use it, like in this example.
Thanks in advance for any help
 i have even been using solid edge spy (trying to anyway) and i can see the path but i cant get VB net to find it.
Posted by: Paul McGiven
Post date: 2/15/2009 9:34:14 PM
RE: Refresh View
Assuming that you've got a Draft file open and the drawing view is on the active sheet:
Application -> ActiveDocument -> ActiveSheet -> DrawingViews(n) -> Update()
Posted by: Jason Newell
Post date: 2/17/2009 1:41:09 PM
