Refresh like key "F5"
Hi
How can i refresh my draft like the keyboard key "F5"
i 've tried that
SendKeys.Send("F5")
but it doesn't work
i want to clear a draft in my macro
Dim SE_DrawingView As SolidEdgeDraft.DrawingView = Nothing
For Each SE_DrawingView In objSheet.DrawingViews
If SE_DrawingView.Shading Then
SE_DrawingView.Shading = False
SE_DrawingView.Update()
End If
Next SE_DrawingView
but after this i need to update my draft with the key F5
thank
Posted by: BONNAUDET eric
Post date: 2/16/2012 6:54:20 AM
Re: Refresh like key "F5"
If your drawing view is the active one, then the following line should help:
objSEApp.ActiveWindow.View.Update()
Posted by: Martin Bernhard
Post date: 2/17/2012 2:11:30 PM
