Reg- Menu building
Hi All I am Jaya
I am a Mechanical engineer and API developer. I dealed with Solidworks API a lot. but in Solidedge I know very few things only. I am good in VB.Net (2003). My SolidEdge is SE V18.
Now I have a requirement to develop a menu bar (like  FIle, View, Edit, Tools) for customizing and inserting commands as per our company's standard. I made a search in this forum and copied the following code, but it does not work. Then what is syntax or procedure for adding a menu.
here is the code I used. Your help is greatly appricated
Region "External References"
Imports Microsoft.VisualBasic
Imports Microsoft.Win32
Imports SolidEdgeFramework
Imports SolidEdgeConstants
Imports System
Imports System.Reflection
Imports System.Runtime.InteropServices
'Imports System.Windows.Forms
Namespace
 EndRegion SEAddin1True)> _PublicClass AddinImplements SolidEdgeFramework.ISolidEdgeAddIn ', SolidEdgeFramework.ISEApplicationEvents, SolidEdgeFramework.ISEAddInEvents
 'Implements SolidEdgeFramework.ISEAddInEvents_Event
 PrivateConst CATID_SolidEdgeAddin = "{25044182-09C2-429a-970C-526AF3007830}"PrivateConst CATID_SEPart = "{424EE515-FCB0-47cf-A34B-B7F8D03512E7}"PrivateConst CATID_SEAssembly = "{BA9AB1F7-EE82-42c0-9351-B9BD82D08E4D}"PrivateConst CATID_SESheetMetal = "{5183E2B6-F4E0-421b-B144-EB6ED89799ED}"PrivateConst CATID_SEDraft = "{89DDB19F-76E5-4aaf-9BC3-68F7277FFC91}"PrivateConst CATID_SEWeldment = "{E2E2A4C9-2017-4689-815C-4C4EB7D88CE5}"'Private addin As SolidEdgeFramework.AddIn
 'Private application As SolidEdgeFramework.Application
 'Private connectionPoints As New Hashtable()
MsgBox("OnConnection")
 Region "On Connection"PublicSub OnConnection(ByVal Application AsObject, ByVal ConnectMode As SolidEdgeFramework.SeConnectMode, ByVal AddInInstance As SolidEdgeFramework.AddIn) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnectionEndSub
#EndRegion
MsgBox("OnConnectToEnvironment")
 Region "On Environment"PublicSub OnConnectToEnvironment(ByVal EnvCatID AsString, ByVal pEnvironmentDispatch AsObject, ByVal bFirstTime AsBoolean) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnectToEnvironmentEndSub
#EndRegion
MsgBox("OnDisconnection")
 Region "On Disconnection"PublicSub OnDisconnection(ByVal DisconnectMode As SolidEdgeFramework.SeDisconnectMode) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnDisconnectionEndSub
#EndRegion
_
 Region "Registering functions"PublicSharedSub Registerfunction(ByVal t As Type)OnErrorResumeNext
Basekey = Registry.ClassesRoot.CreateSubKey("CLSID\{" + t.GUID.ToString() + "} ")
 Dim Basekey As RegistryKeyIfNot (Basekey IsNothing) Then
Basekey.SetValue("AutoConnect", 1)
Basekey.SetValue("409", "SEAddin")
Basekey.CreateSubKey("Implemented Categories\" & CATID_SolidEdgeAddin)
Basekey.CreateSubKey("Environment Categories\" & CATID_SEAssembly)
Basekey.CreateSubKey("Environment Categories\" & CATID_SEDraft)
Basekey.CreateSubKey("Environment Categories\" & CATID_SEPart)
Basekey.CreateSubKey("Environment Categories\" & CATID_SESheetMetal)
Basekey.CreateSubKey("Environment Categories\" & CATID_SEWeldment)
Basekey.Close()
 EndIf
 EndSub
#EndRegion
_
 Region "UnRegister Function"PublicSharedSub UnRegisterFunction(ByVal t As Type)OnErrorResumeNext
Registry.ClassesRoot.DeleteSubKeyTree("CLSID\(" + t.GUID.ToString() + ")")
 EndSub
#EndRegion
EndEndClassNamespace
Jaya
Posted by: jaya priyan
Post date: 12/17/2007 10:57:03 PM
RE: Reg- Menu building
I replied here
Posted by: Jason Newell
Post date: 12/19/2007 8:01:41 PM
Hi jaya,
This is Prasad. R u from India? I am also not old to SE customization.So any help would be appriciated. Thanks
Posted by: Prasad Pawar
Post date: 12/19/2007 9:09:02 PM
Hi Prasad
Nice to hear from you. You are right, I am from India. I am Good in Solidworks Customization. But now we bought SE licence. So I need build menus (like file, edit, view...). Have you ever built like this ? If provide some Ideas to me.
Jaya
Post date: 12/19/2007 9:22:25 PM
After a long try I am able to create the toolbar.
Here are some more doubts.
What is the syntax for creating Menu (like File, Edit, View)?
How to change the calculator image buttom in MYToolBar?
How to add commands for the toolbar buttons?
Jaya
Post date: 12/20/2007 2:49:04 AM
Jaya,
Everything that you need can be found in this post.  You also need to read "C:\Program Files\Solid Edge VXX\SDK\Samples\Addins\Doc\addin.doc".
The fact still stands that you can only develop with VS.NET 2005 for Solid Edge V19 and higher.
Post date: 12/21/2007 9:45:03 PM
Jason.
Is this true that for v19 and higher you can only develop in vs.net 2005?  I am still able to run and modify my existing code in vb6.
Posted by: Carl Breving
Post date: 1/26/2009 7:35:12 AM
Carl,
The discussion was specific to .NET.  VB6 is not affected by this discussion because it was pre-.NET.
Post date: 1/27/2009 6:02:09 AM
