Remove/Replace Links
Good evening!
&Sorry for my English!
I have a few questions:
For example, i have two ASM files: c:\folder1\first.asm, c:\folder2\second.asm
first.asm has two links to two files c:\folder1\first.par and c:\folder1\second.par
second.asm has two links to two files c:\folder2\first.par and c:\folder2\second.par
Files c:\folder1\first.par and c:\folder2\first.par are the same
Files c:\folder1\second.par and c:\folder2\second.par are the same too
I want to change links in the next way:
first.asm has link to c:\folder1\first.par and c:\folder1\second.par
second.asm has link to c:\folder1\first.par and c:\folder1\second.par
So, I need to remove old link and to made a new link?
Or, I need to replace old link with new link?
What method should I use?
try
application = new RevisionManager.Application();
document = (Document)
application.Open(sourceFilePath, RevisionRuleType.LatestRevision, false);
linkedDocuments = (LinkedDocuments)
document.LinkedDocuments[LinkTypeConstants.seLinkTypeAll];
for (var i = 1; i <= linkedDocuments.Count; i++)
linkedDocument = linkedDocuments.Item[i] as Document;
try
[b]linkedDocument.Replace(newLinkFilePath);
linkedDocument.SaveAllLinks();
document.SaveAllLinks();[/b]
I do it in right way?
Or I need to use RedefineLinks method?
Can someone write a little example? VB or C#?
Thanks a lot!!!
Posted by: Nick
Post date: 3/1/2012 10:24:09 AM
Re: Remove/Replace Links
Nick,
open the file second.asm via the RevisionManager.Application object, traverse its LinkedDocuments collection and set the path of each LinkedDocument which path you want to replace with a new path via its method SetPath.
Posted by: Wolfgang Kunert
Post date: 3/2/2012 3:10:56 AM
Hello Nick, hello Wolfgang,
the solution you offer works perfectly for assemblies and parts but doesnt seem to update paths to linked documents for drafts.. Any idea why or how could it be done?
Thanks in advance,
Salwadora
Posted by: Salwadora
Post date: 1/14/2013 8:35:04 AM
well, thats sad..
I have a 3D Model and a draft linked to the .asm file of this model and whenever I need to copy it to another directory I have to reistablish the links in revisison manager. So I am doing it like this:
Dim reApp As RevisionManager.Application
Dim reDoc, reDoc1 As RevisionManager.Document
Dim reLinkedDocs As RevisionManager.LinkedDocuments
Dim reLink As RevisionManager.Document = Nothing
Try
reApp = DirectCast(CreateObject("RevisionManager.Application"), RevisionManager.Application)
System.Windows.Forms.Application.DoEvents()
reDoc = DirectCast(reApp.Open(NewPath + "Zusammenbau.asm"), RevisionManager.Document)
reLinkedDocs = DirectCast(reDoc.LinkedDocuments, RevisionManager.LinkedDocuments)
'replacing the links for a 3D Model
For Each reLink In reLinkedDocs
If reLink.FullName.Substring(reLink.FullName.LastIndexOf("\") + 1) = "Siebkasten.asm" Then
reLink.Replace(NewPath + "\Siebkasten\Siebkasten.asm")
End If
Next
reDoc.SaveAllLinks()
' replacing links for a draft (it linked to Zusammenbau.asm which i updated above
reDoc1 = DirectCast(reApp.Open(NewPath + fName + ".dft"), RevisionManager.Document)
reLinkedDocs = DirectCast(reDoc1.LinkedDocuments, RevisionManager.LinkedDocuments)
If reLink.FullName.Substring(reLink.FullName.LastIndexOf("\") + 1) = "Zusammenbau.asm" Then
reLink.Replace(strASMFile + "Zusammenbau.asm")
reDoc1.SaveAllLinks()
End If
Next
Catch ex As Exception
MsgBox(ex.Message)
Finally
Marshal.ReleaseComObject(reDoc)
Marshal.ReleaseComObject(reLinkedDocs)
reApp.Quit()
reApp = Nothing
reDoc = Nothing
reLinkedDocs = Nothing
End Try
Is there any way to update these links for a draft file? After copying files elsewhere the draft file is still linked to asm in old location which doesnt exist...
Any help is highly appreciated
Post date: 1/15/2013 2:32:06 AM
tried it, didnt work..
Post date: 1/15/2013 4:29:39 AM
Hello Wolfgang,
i dont know what the problem was. Not mine neither your code would work for me. So i created another project, recreated there all my classes and modules from the old project and now it works perfectly. Whatever coused my problem now its sloved.
Thank you very much for your help, i really appreciate it!
salwadora
Post date: 1/17/2013 1:43:21 AM
