Remove callout from SolidEdge daft
Beginner here
I want to remove a callout from a draft doc using VB6
Posted by: Scott Smith
Post date: 9/14/2009 7:35:39 AM
RE: Remove callout from SolidEdge daft
If you want to delete a callout with the text "My text":
Private Sub Main()
Set seApp = GetObject(, "SolidEdge.Application")
'seApp.DisplayAlerts = False
Set seDraft = seApp.ActiveDocument
For i = 1 To seDraft.Sheets.Count
With seDraft.Sheets(i)
100 For x = 1 To .Balloons.Count
If .Balloons.Count = x Then
GoTo 200
ElseIf .Balloons(.Balloons.Count - x).balloontext = "My Text" Then
.Balloons(x).Delete
GoTo 100
End If
Next
End With
200 Next
Set seDraft = Nothing
Set seApp = Nothing
End Sub
Posted by: Bill Ledbetter
Post date: 9/14/2009 8:20:34 AM
Thanks for the help, I'll try it
Post date: 9/14/2009 9:09:15 AM
Bill
Is a SE Callout Anotation and a Balloon Callout the same SE object?
What I'm trying to remove is an SE Callout Anotation
Per your code can I use an incomplete "My text string here" to locate the callout in the array.
in other words if my callout has 20 words can i substitue "My text string" with the first 3 words
and not the whole text string.
Post date: 9/14/2009 9:36:57 AM
You have two questions here:
1. Yes, an Annotation Callout is considered part of the Balloons collection.
2. To use a known string, or parts of it, just use the Left() function. For example:
If Left(.Balloons(x).balloontext,13) = "My known text" Then
.Balloons(x).Delete
End If
Or you can alternatively search the entire Callout for an instance of your string using the Instr function.
Post date: 9/15/2009 12:38:07 AM
Got it thanks
Post date: 9/15/2009 11:34:33 AM
