Replace part tool
Dear experts,
Maybe here I obtain a solution of my issue. I am seeking a support in case that I have a real problem.
My company database contains hundreds of machine assemblies, SE ST5. There is a task to do: Replace parts in these assemblies for standard elements. All those std parts are unmaneged.
I would like to replace all parts faster than using option: redefine links or replace in Rev Manager.
Is there any tool includes such a operation? May you help me please?
Thank you.
Re: Replace part tool
Revision Manager is the way to go.
Any other direct access to the assembly documents needs a complete understanding of the internal structure of those documents and is, of course, not supported by Siemens!!
BTW: You can also automate RevMgr and run your batch overnight...
