Replacing Solid Edge Assembly References using API
Hi All, I'm coming from SolidWorks background, and need help in Solid Edge API for replacing assembly references.
I tried folowing method, but it is not working :
oapp.ReplaceReference(oldnamewithext, oldnamewoext + "_" + newdir + "." + ext, outpath + "\" + newdir, False)
Need your help. Thanks.
Re: Replacing Solid Edge Assembly References using API
Thanks Tushar Suradkar for suggesting oasm.replacecomponents method. Here is my code which works :
oapp = Marshal.GetActiveObject("SolidEdge.Application")
odoc = oapp.Documents.Open("C:\sabc123\coupling_sabc123.asm")
oasm = odoc
For i = 1 To oasm.Occurrences.Count
Dim ooccu As SolidEdgeAssembly.Occurrence = oasm.Occurrences.Item(i)
Dim sa As System.Array = {ooccu}
oldnamewithextinst = ooccu.Name.Substring(ooccu.Name.ToString.LastIndexOf("\") + 1)
oldnamewithext = oldnamewithextinst.Substring(0, oldnamewithextinst.LastIndexOf(":"))
oldnamewoext = oldnamewithext.Substring(0, oldnamewithext.LastIndexOf("."))
ext = oldnamewithext.ToString.Substring(oldnamewithext.ToString.LastIndexOf(".") + 1)
newname = txtOutPath.Text + "\" + txtNewDirName.Text + "\" + oldnamewoext + "_" + txtNewDirName.Text + "." + ext
oasm.ReplaceComponents(sa, newname, ConstraintReplacementConstants.seConstraintReplacementNone)
Next
Glad to know 'ReplaceComponents' worked.
Also, I'd like to suggest the following direct functions in DotNet to replace extensions:
System.IO.Path.GetFileNameWithoutExtension
System.IO.Path.ChangeExtension
Hope you find them useful.
Tushar
