Retrive info about Part and Assembly FamilyMembers
HI,
without opening SolidEdge
it's possible to retrive:
1. List of FamilyMembers of parts or assemblies?
2. Which member was active when document was saved?
(maybe Revision Manager can do this? StructuredStorage?)
Thanks in advance for any info.
Best Regards
Massimo
Posted by: Massimo Magris
Post date: 2/27/2009 4:30:11 AM
RE: Retrive info about Part and Assembly FamilyMembers
Hi Massimo,
I don't know where the FOP Members are hidden but for the FOA members you can check out the code here
I have attached the c++ code file with the family of assemblies code.
Hope this helps,
Calum
Posted by: Calum McLellan
Post date: 3/1/2009 9:06:53 PM
HI Calum,
thanks!!
It's really of help.
Massimo
Post date: 3/1/2009 10:36:31 PM
