Revision Manager API - Reading File Properties (C#) Example doesn't work
On the ".NET Programmer's Guide" of SE ST
propertySets.Open(@"C:\Part1.par", true);
line of the code gives an error message "Object reference not set to an instance of an object". Any idea for what could be the reason?
Ozlem ILDAY
RevisionManager.Application application = null;
RevisionManager.PropertySets propertySets = null;
RevisionManager.Properties properties = null;
RevisionManager.Property property = null;
string strFormat1 = "[{0}]";
string strFormat2 = "{0} = {1}";
try
 // Create new instance of the Revision Manager Application object
 application = new RevisionManager.Application();
 // Open a file
Posted by: Ozlem ILDAY
Post date: 4/24/2009 7:16:27 AM
4 REPLIES 4
RE: Revision Manager API - Reading File Properties (C#) Example doesn't work
Seems you've found an error in the documentation. If you will go up a page or two and look at the VB.NET version, you'll see the correct syntax. Should be something like application.Open() instead of propertySets.Open().
You need to send an email to seedumedia@ugs.com to nofity them of the error.
Posted by: Jason Newell
Post date: 4/24/2009 7:22:37 AM
Thanks Jason,
I will take a look at  the VB version of the example.
Ozlem ILDAY
Post date: 4/24/2009 7:39:08 AM
Hope this helps you:
Dim oRevMgr As RevisionManager.Application
Dim RevMgrDoc As RevisionManager.Document
Dim oRevlinkedDocs As RevisionManager.LinkedDocuments
Dim oRevlinkedDoc As Object
Dim i As Integer
Dim name As String
oRevMgr = CreateObject("RevisionManager.Application")
RevMgrDoc = oRevMgr.Open(FileName)
oRevlinkedDocs = RevMgrDoc.LinkedDocuments
For i = 1 To oRevlinkedDocs.Count
oRevlinkedDoc = oRevlinkedDocs.Item(i)
name = oRevlinkedDoc.FullName
Next
RevMgrDoc.SaveAllLinks()
oRevMgr.Quit()
oRevlinkedDoc = Nothing
oRevlinkedDocs = Nothing
RevMgrDoc = Nothing
oRevMgr = Nothing
Posted by: Prasad Pawar
Post date: 4/24/2009 6:33:17 PM
Prasad,
Thank you for your reply. I've already using a similar code for linked documents. I don't have problems for the filenames. The question is how we can read the properties of linked documents.
Jason,
I tried to apply the same method of VB.NET version in my C# code, but unfortunatelly server threw an exception. Am I missing something?
// Open a file
application.Open(FileName, 0, true);
//Get a reference to the property sets collection
propertySets = (RevisionManager.PropertySets)application.PropertySets;
Post date: 4/27/2009 1:10:07 AM
