Revision Manager FindWhereUsedOnServer
Hello everybody,
I'm Alex, SE admin for a Swiss Railway Company.
First of all I would like to thanks everybody on this forum for all the contributions made.
I'm trying to do a macro for ST5 using VBA Express and I'm not really a developper, I'm beginner.
My question is about the function "FindWhereUsedOnServer". I would like to open the drawing of the active document  (3D files asm, par or psm). We use Insight.
I searched on this forum something about the function "FindWhereUsedOnServer" but I didn't found the help needed that why I decide to write this topic if someone could help me please. Smiley Very Happy
Below here is the code I found on your forum and that seems correct, but I don't know how to get the result of the search, in fact the value that will allow me to open the draft file.
Many Thanks
Alex
Option Explicit On
Imports System.IO
Imports System.Runtime.InteropServices
Imports Microsoft.Office.Interop
Imports RevisionManager
Imports Microsoft.Vbe.Interop.Forms
        Dim objApp As SolidEdgeFramework.Application
        Dim objRev As RevisionManager.Application
        Dim objDocuments As SolidEdgeFramework.Documents
        Dim objLinks As RevisionManager.LinkedDocuments
        Dim objDocument As SolidEdgeFramework.SolidEdgeDocument
        Dim objPart As SolidEdgePart.PartDocument
        Dim objdraft As SolidEdgeDraft.DraftDocument
        Dim revManType As Type
        Dim revMan As RevisionManager.Application
        Dim insight As RevisionManager.Insight
        objApp = Marshal.GetActiveObject("SolidEdge.Application")
        objDocument = objApp.ActiveDocument
        revManType = Type.GetTypeFromProgID("RevisionManager.Application")
        Try
            revMan = Activator.CreateInstance(revManType)
            revMan.Visible = False
            revMan.DisplayAlerts = False
        Catch ex As Exception
            MsgBox("Cannot start Revision Manager.")
        End Try
         insight = revMan.Insight()
        Dim numberOfProperties As Integer = 1
        Dim listOfProperties() As Object = New Object() {""}
        Dim numberOfSharePointDirectories As Integer = 1
        Dim listOfSharePointDirectories() As Object = New Object() {"http://cad-solidedge/"}
        Dim numberOfDocumentsForWhereUsed As Integer = 1
        Dim listOfDocumentsForWhereUsed() As Object = New Object() {objDocument}
        Dim numberOfUsedFiles As Integer
        Dim listOfDocumentsUsed As Object
        Dim typeOfSearch As Object = 1 ' DeepSearch - 0 for Shallow Search
        insight.FindWhereUsedOnServer(numberOfProperties, listOfProperties, numberOfSharePointDirectories, listOfSharePointDirectories, numberOfDocumentsForWhereUsed, listOfDocumentsForWhereUsed, numberOfUsedFiles, listOfDocumentsUsed, typeOfSearch)
        If numberOfUsedFiles > 0 Then
        Dim count As Integer
        Dim message As New System.Text.StringBuilder
        For count = 0 To numberOfUsedFiles - 1
        message.Append(listOfDocumentsUsed(count))
        message.Append(ControlChars.CrLf)
        Next
        MsgBox(message.ToString())
        End If
        revMan.Quit()
Re: Revision Manager FindWhereUsedOnServer
The Insight object can be accessed from the objApp.Insight() also and is probably what you want.
  insight = objApp .Insight()
listOfDocumentsUsed will be filled with the list of files that reference yours.
listOfDocumentsForWhereUsed is the url of your model.
LMGi
www.TLMGi.com
Hi Jason,
Thank you for your fast answer.
Actually I changed like your advice. But now I have an error on the last lign:
insight.FindWhereUsedOnServer...
Dim listOfDocumentsForWhereUsed() As Object = New Object() {objDocument.FullName}
insight.FindWhereUsedOnServer(numberOfProperties, listOfProperties, _
                                      numberOfSharePointDirectories, _
                                      listOfSharePointDirectories, _
                                      numberOfDocumentsForWhereUsed, _
                                      listOfDocumentsForWhereUsed, _
                                      numberOfUsedFiles, _
I see that the application(SE) is trying to do something but there is error at the final....
Do you have any idea why?
Thanks again
Hi @Aca_Speno,
I have modified your code to get the list of files using "FindWhereUsedOnServer" method
You can use below code and let me know if it works for you.
Instead of using Insight object, I am using "FindWhereUsedOnServer" method available on Revision Manager object and I could get the list of files as expected.
Module Module1
    Sub Main()
        Dim revMan As RevisionManager.Application = Nothing
        Dim insight As RevisionManager.Insight = Nothing
        Dim objDocument As RevisionManager.Document = Nothing
        Try
            Try
                revMan = Marshal.GetActiveObject("RevisionManager.Application")
                revMan = Activator.CreateInstance(Type.GetTypeFromProgID("RevisionManager.Application"))
                revMan.Visible = True
                revMan.DisplayAlerts = True
                'MsgBox("Cannot start Revision Manager.")
            End Try
            'objDocument = revMan.OpenFileInRevisionManager("http://ServerName/sites/insight/pre/Prerelease/DK/TestBox.par")
            Dim listOfSharePointDirectories() As Object = New Object() {"http://Servername/"}
            Dim listOfDocumentsForWhereUsed(0 To 1) As Object '= New Object() {objDocument}
            Dim listOfDocumentsUsed As Object = Nothing
            listOfDocumentsForWhereUsed(0) = "http://ServerName/sites/insight/pre/Prerelease/DK/TestBox.par" 'objDocument.FullName
            revMan.FindWhereUsedOnServer(numberOfProperties, listOfProperties, numberOfSharePointDirectories, _
                                          listOfDocumentsUsed, _
                                          typeOfSearch)
                Next
            End If
            Console.WriteLine(ex.ToString)
        Finally
            revMan.Quit()
        End Try
    End Sub
End Module
If you would like to use "FindWhereUsedOnServer" method available on insight object then you can use below code instead of "revman.FindWhereUsedOnServer".
            insight.FindWhereUsedOnServer(numberOfProperties, listOfProperties, numberOfSharePointDirectories, _
                                          typeOfSearch)
