Rotate camera clock/counterclockwise
Hi guys,
I'm using C# and I'm trying to rotate the camera clock/counterclockwise, but I couldn't figure out what's the calculation to determine the new X,Y,Z for doing that. Here's an example:
In this case it's easy, it's just rotating the Y axis:
Picture 1
Result:
But if the object is in a different position, I need to rotate another axis instead.
I found some similar questions in the forum but none of them are exactly what I'm looking for.
Here's my code:
public void RotateFace(int angle, bool isClockwise)
   var axis = new double[3];
   // Just rotating Y axis
   axis[0] = 0;
   axis[1] = isClockwise ? 1 : -1;
   axis[2] = 0;
   view.RotateCamera(angle, 0, 0, 0, axis[0], axis[1], axis[2]);
Thanks everyone.
9 REPLIES 9
Re: Rotate camera clock/counterclockwise
Josh,
I just wanted to let you know that I'm deeply interested in what you're trying to do. I wish so bad that I understood the math side of CAD better. My lack of a good math education is showing...
I spoke with a dear friend of mine, John Hilton, on Skype tonight. John is absolutely amazing with this kind of stuff but getting his time is difficult. I poked and prodded him to jump in here and answer your question so we'll have to wait and see if he has time. Fingers crossed.
Jason Newell
Solutions Architect
www.jasonnewell.net
Hi Jason,
Thanks for the effort, man. Hopefully he'll show up here. Last time I've asked something related to that in this forum, a guy called Martin helped me a lot. Seems he's no longer here though.
Josh,
hope I understand your requirements.
In the video below I transformed the rootpoint and the normalvector of the refplane at the tip of the arrows to the topassembly and used
view.RotateCamera(angle, X(rootpoint), Y(rootpoint), Z(rootpoint), _
                                     n*X(normalvector), n*Y(normalvector), n*Z(normalvector))
Rotate Camera
Gerald
Hi Gerald, youtube says the video is private. Can you make it public, please? Or maybe post some pieces of code here? Thanks
Josh,
the video is public now.
I wrote a module to get and transform Rootpoint, Normalvector and Matrix, it works for me but unfortunately I don't really know why.
Occurrence.GetMatrix TM(1 to 16)
RefPlane.GetRootPoint RP(1 to 3)
RefPlane.GetNormal NV(1 to3)
For i = 1 to 3
  RP_Transformed= TM(i) * RP(1) + TM(i + 4) * RP(2) + TM(i + 8) * RP(3) + TM(i + 12)
  NV_Transformed= TM(i) * NV(1) + TM(i + 4) * NV(2) + TM(i + 8) * NV(3)
next
RP_Transformed and NV_Transformed are my values to rotate the camera.
HTH
Gerald
Hi Gerald,
Thanks for your reply. In your video you are pretty much rotating axis X, Y and Z individually. I'm looking for some sort of calculation to rotate all of them at once, no matter what's the current position of the object. I think it would be something like this:
var eye = new double[3];
var target = new double[3];
var up = new double[3];
var isPerspective = false;
double scale = 0;
view.GetCamera(out eye[0], out eye[1], out eye[2], out target[0], out target[1], out target[2], out up[0], out up[1], out up[2], out isPerspective, out scale);
const int angle = 20;
// Compute the normalized view direction
var viewDir = new double[3];
viewDir[0] = target[0] - eye[0];
viewDir[1] = target[1] - eye[1];
viewDir[2] = target[2] - eye[2];
double len = Math.Sqrt(viewDir[0] * viewDir[0] + viewDir[1] * viewDir[1] + viewDir[2] * viewDir[2]);
if (len > 1.0E-5)
   viewDir[0] /= len;
   viewDir[1] /= len;
   viewDir[2] /= len;
// var axis = DO SOME CALCULATION HERE TO DETERMINE X, Y, Z
Josh,
it depends on the position of the arrow.
Gerald
Josh,
if you want to rotate around the axis of the camera like in the video below you can use
view.RotateCamera(angle, out target[0], out target[1], out target[2], out eye[0] - out target[0], out eye[1] - out target[1], out eye[2] - out target[2]);
Gerald
Gerald, you the guy! With your code I could achieve what I was looking for! Thanks man
