SAFEARRAY
I am using C++...so far I am able to create profile on one of reference plane
and added 2d relation ships on those entities(4 lines shapes of square, but I have difficulties to protrude those entities to cebic shape using "SAFEARRAY" see below for code I am using but I am not sure about how to use "LPSAFEARRAY" please help
Thank you
MdlPtr=MdlsPtr->AddFiniteExtrudedProtrusion(1,LPSAFEARRAY* PofileArray, Solidedgepart_tlb::igRight, 1.0*0.0254);
Posted by: Terry Goto
Post date: 3/30/2007 6:09:10 AM
RE: SAFEARRAY
Terry,
My VS.NET 2005 addin wizard generates code that uses SAFEARRAY's. See the following example. I'll be out of town this weekend so I can't work up a better example for you. Reply back and let me know how it goes.
STDMETHODIMP CConnect::raw_OnConnectToEnvironment( BSTR EnvironmentCatid, LPDISPATCH pEnvironment, VARIANT_BOOL bFirstTime )
HRESULT hr = S_OK;
CComBSTR bstrCommands[NUMBER_OF_COMMANDS];
CComBSTR bstrCategory;
SAFEARRAY *pCmdStrings = NULL;
SAFEARRAY *pCmdIDs = NULL;
CLSID clsid;
try
/* Populate command string array */
for (int i = 0; i
bstrCommands.LoadString(IDS_COMMAND_1 + i);
bstrCategory.LoadString(IDS_CATEGORY);
/* Allocate Safe Arrays */
pCmdStrings = SafeArrayCreateVector(VT_BSTR, 0, NUMBER_OF_COMMANDS );
pCmdIDs = SafeArrayCreateVector(VT_I4, 0, NUMBER_OF_COMMANDS );
/* Ensure Safe Array Allocation */
if (pCmdStrings && pCmdIDs)
/* Populate Safe Arrays */
for (long index = 0; index
hr = SafeArrayPutElement(pCmdStrings, &index, bstrCommands[index].Detach());
hr = SafeArrayPutElement(pCmdIDs, &index, &index);
/* Configure AddIn */
hr = m_pAddin->SetAddInInfo(HandleToLong( _AtlModule.GetResourceInstance()),
EnvironmentCatid, bstrCategory.m_str,
IDB_TOOLBAR_SMALL, IDB_TOOLBAR_LARGE,
NUMBER_OF_COMMANDS,
&pCmdStrings, &pCmdIDs);
/* Convert BSTR -> CSLID */
CLSIDFromString(EnvironmentCatid, &clsid);
/* Store the runtime command ids for later use */
m_pEventManager->SetEnvironmentCommandIds(clsid, NUMBER_OF_COMMANDS, pCmdIDs);
/* Deallocate Safe Array */
hr = SafeArrayDestroy(pCmdStrings);
hr = SafeArrayDestroy(pCmdIDs);
#ifdef SE_ADDIN_TOOLBAR
if (bFirstTime == VARIANT_TRUE)
CommandBarButtonPtr pButton = m_pAddin->AddCommandBarButton( EnvironmentCatid, bstrCategory.m_str, index);
#endif
catch(_com_error &e)
hr = e.Error();
return hr;
Posted by: Jason Newell
Post date: 3/30/2007 8:05:10 AM
RE: SAFEARRAY
Hi Terry,
LPSAFEARRAY is a "Long Pointer" to a SAFEARRAY. Meaning that LPSAFEARRAY* is a pointer to a pointer to a SAFEARRAY (or a SAFEARRAY pointer passed by reference)
Check out the CComSAFEARRAY ATL class. It's a bit easier to use than the SAFEARRAY macros.
Here's the code that Jason posted using CComSAFEARRAY (the CComSAFEARRAY::GetSafeArrayPtr() method returns a LPSAFEARRAY*):
/* Set up the SAFEARRAYS for the call to
SetAddInInfo */
CComBSTR temp;
CComSafeArray cmdIDs(NUMBER_OF_COMMANDS);
CComSafeArray cmdNames(NUMBER_OF_COMMANDS);
HRESULT hr;
for (long i = 0; i
cmdIDs.SetAt(i, i);
temp.LoadString(IDS_COMMAND_1 + i);
hr = cmdNames.SetAt(i, temp.Detach(), false);
if (FAILED(hr)) return hr;
temp.LoadString(IDS_CATEGORY);
// TODO: Store the runtime command ids for each environment
hr = m_seAddIn->raw_SetAddInInfo(
HandleToLong(_AtlBaseModule.GetResourceInstance()),
EnvCatID, temp, IDB_TOOLBAR_SMALL, IDB_TOOLBAR_LARGE,
IDB_TOOLBAR_SMALL, IDB_TOOLBAR_LARGE, NUMBER_OF_COMMANDS,
cmdNames.GetSafeArrayPtr(), cmdIDs.GetSafeArrayPtr());
Cheers
Calum
Posted by: Calum McLellan
Post date: 4/2/2007 1:59:26 AM
RE: SAFEARRAY
I am not sure what kind of VT_**** uses for Profile array??
Is it VT_BSTR? VT_DISPATCH?
I tried below but did not work
pls help
Thank you
Terry
long indices=0;
VARIANT Vsfarry03;
LPSAFEARRAY prfarray;
LPDISPATCH Etp;
Etp = PfPtr->ProjectEdge(Etp); // PfPtr is a pointer to the profile I have 4 lines
Vsfarry03.vt=VT_DISPATCH;
Vsfarry03.pdispVal=Etp;
prfarray = SafeArrayCreateVector(VT_DISPATCH, 0, 1);
SafeArrayPutElement(prfarray, &indices, &Vsfarry03);
Post date: 4/2/2007 8:04:28 AM
RE: SAFEARRAY
Terry,
Take a closer look at Calum's use of CComSafeArray. I think you'll find his way much easier to use. There I go again doing things the hard way
Post date: 4/2/2007 2:45:39 PM
RE: SAFEARRAY
Hi Terry,
Here's an example I wrote a while back (sorry, I forgot I had this )
PartDocumentPtr partDoc = NULL;
HRESULT hr =
m_seApp->ActiveDocument->QueryInterface(&partDoc);
if (hr != S_OK)
partDoc = m_seApp->Documents->Add
(__T("SolidEdge.PartDocument"));
if (partDoc)
ProfileSetPtr profileSet =
partDoc->ProfileSets->Add();
RefPlanePtr refPlane =
partDoc->RefPlanes->Item((long)1);
ProfilePtr profile =
profileSet->Profiles->Add
(refPlane);
LRESULT pos = SendMessage(GetDlgItem((HWND)m_hwnd, IDC_SLIDER1),
(UINT) TBM_GETPOS, 0, 0);
double size = (((double)pos +1)/200);
profile->Lines2d->AddBy2Points(-size, -size, -size, size);
profile->Lines2d->AddBy2Points(-size, size, size, size);
profile->Lines2d->AddBy2Points(size, size, size, -size);
profile->Lines2d->AddBy2Points(size, -size, -size, -size);
CComSafeArray profiles(1);
profiles.SetAt(0, profile);
hr = partDoc->Models->AddFiniteExtrudedProtrusion(1,
profiles.GetSafeArrayPtr(), igSymmetric, (size*2));
I use IUnknown* (VT_UNKNOWN) for the CComSAFEARRAY.
The IDC_SLIDER1 control is just a slider that sets the size (just playing around...)
Hope this helps
Calum
Post date: 4/2/2007 7:49:57 PM
RE: SAFEARRAY
What type library do I have to import in order to use CComSAFEARRAY class?
Thank you
Terry
Post date: 4/3/2007 2:11:27 AM
RE: SAFEARRAY
Hi Terry,
add the following include to your header:
#include
Cheers
Calum
Post date: 4/3/2007 2:24:42 AM
RE: SAFEARRAY
My compiler (C++ Builder) does not have this atlsafe.h so I need to go in hard way defining SAFEARRAY, please help...
Thank you
Terry
Post date: 4/3/2007 4:12:15 AM
RE: SAFEARRAY
Hi Terry
atlsafe.h is in "C:\Program Files\Microsoft Visual Studio 8\VC\atlmfc\include". This may just be a part of Visual Studio, or it may be installed with the VC++ 2005 redistributable (available here).
If it's not a part of the redist. then this should work (I'm writing this on the fly, so there may be the odd small error):
Instead of:
Try:
SAFEARRAY* pProfiles = NULL;
/* Allocate Safe Array */
pProfiles = SafeArrayCreateVector(VT_UNKNOWN, 0, 1 );
if (pProfiles)
/* Populate Safe Array */
long index = 0;
hr = SafeArrayPutElement(pProfiles, &index, profile);
if (SUCCEEDED(hr))
&pProfiles, igSymmetric, (size*2));
Cheers
Calum
Post date: 4/3/2007 8:01:45 PM
