SE 19, VB 6, GetDimensions does not work
SE 19, VB 6
The following code returns run-time error -2147023113 (Method 'GetDimensions' of object 'ExtrudedProtrusion' failed).
I've tried everything, searched help but unable to find out the reason for error. Please help.
    Dim dims1() As Object ' Tried other names
    Dim noOfDims As Long ' tried Integer
    Dim feat As ExtrudedProtrusion
'    Set feat = partDoc.Models(1).Features(1)
    Set feat = partDoc.Models(1).ExtrudedProtrusions(1)
    MsgBox feat.Name
    '''' Works fine upto here
    feat.GetDimensions noOfDims, dims1() '' Error
- S S Kulkarni
Posted by: Sanjay Kulkarni
Post date: 1/6/2009 12:23:50 AM
