SE API with C++/Draft-section/sheet
    SolidEdgeFramework::ApplicationPtr pSEApp;
    SolidEdgeFramework:Smiley Very HappyocumentsPtr pDocs;
    SolidEdgeDraft:Smiley Very HappyraftDocumentPtr pDraftDoc;
    SolidEdgeDraft:Smiley FrustratedectionsPtr pSections;
    SolidEdgeDraft:Smiley FrustratedectionPtr pSection;
    SolidEdgeDraft:Smiley FrustratedectionSheetsPtr pSectionSheets;
    SolidEdgeDraft:Smiley FrustratedheetsPtr pSheets;
    SolidEdgeDraft:Smiley FrustratedheetPtr pSheet;
    CString format1;
    CString format2;
    IDispatchPtr pDispatch;
    HRESULT hr;
    hr=pSEApp.GetActiveObject("SolidEdge.Application");
    pDocs=pSEApp->Documents;
    pDispatch=pDocs->Add("SolidEdge.DraftDocument",vtMissing);
    hr=pDispatch->QueryInterface(&pDraftDoc);
    pSections=pDraftDoc->Sections;
    int type;
    for(long i=1;iCount;i++)
        pSection=pSections->Item(i);
        pSectionSheets=pSection->Sheets;
        type=(int)pSection->Type;
        format1.Format("%d",type);
        MessageBox(format1,"xx",0);
        for(long j=1;jCount;j++)
            pSheet=pSectionSheets->Item(j);
            format2=pSheet->Name.Detach();
            MessageBox(format2);
        pSection=pSections->WorkingSection;
        pSection=pSections->BackgroundSection;
        pSheets=pDraftDoc->Sheets;
        if(i==1)
            pSheet=pSheets->AddSheet("Sheet2",igWorkingSection,vtMissing,vtMissing);
        else if(i==2)
            pSheet=pSheets->AddSheet("Sheet3",igWorkingSection,vtMissing,vtMissing);
        else
        pSheet->Activate();
Posted by: assassin 007
Post date: 5/16/2010 7:49:46 PM
