SE API with C++/Place dimension and change it via varialbe
    SolidEdgeFramework::ApplicationPtr pSEApp;
    SolidEdgeFramework:Smiley Very HappyocumentsPtr pDocs;
    SolidEdgePart:Smiley TongueartDocumentPtr pPartDoc;
    SolidEdgePart:Smiley FrustratedketchsPtr pSketchs;
    SolidEdgePart:Smiley FrustratedketchPtr pSketch;
    SolidEdgePart:Smiley TonguerofileSetsPtr pProfileSets;
    SolidEdgePart:Smiley TonguerofileSetPtr pProfileSet;
    SolidEdgePart:Smiley TonguerofilesPtr pProfiles;
    SolidEdgePart:Smiley TonguerofilePtr pProfile;
    SolidEdgePart::RefPlanesPtr pRefPlanes;
    SolidEdgeFrameworkSupport::Relations2dPtr pRelations2d;
    SolidEdgeFrameworkSupport::Relation2dPtr pRelation2d;
    SolidEdgeFrameworkSupport::Lines2dPtr pLines2d;
    SolidEdgeFrameworkSupport::Line2dPtr pLine2d;
    SolidEdgeFrameworkSupport:Smiley Very HappyimensionsPtr pDims;
    SolidEdgeFrameworkSupport:Smiley Very HappyimensionPtr pDim1,pDim2;
    IDispatchPtr pDispatch;
    HRESULT hr;
    hr=pSEApp.GetActiveObject("SolidEdge.Application");
    pDocs=pSEApp->Documents;
    pDispatch=pDocs->Add("SolidEdge.PartDocument",vtMissing);
    hr=pDispatch->QueryInterface(&pPartDoc);
    pSketchs=pPartDoc->Sketches;
    pSketch=pSketchs->Add();
    pProfiles=pSketch->Profiles;
    pRefPlanes=pPartDoc->RefPlanes;
    pProfile=pProfiles->Add(pRefPlanes->Item((long)3));
    pLines2d=pProfile->Lines2d;
    pLines2d->AddBy2Points(0,0,0.08,0);
    pLines2d->AddBy2Points(0.08,0,0.08,0.1);
    pLines2d->AddBy2Points(0.08,0.1,0,0.1);
    pLines2d->AddBy2Points(0,0.1,0,0);
    pDispatch=pProfile->Relations2d;
    hr=pDispatch->QueryInterface(&pRelations2d);
    pRelations2d->AddKeypoint(pLines2d->Item(1),SolidEdgeConstants::KeypointIndexConstants::igLineEnd,
                              pLines2d->Item(2),SolidEdgeConstants::KeypointIndexConstants::igLineStart,true);
    pRelations2d->AddKeypoint(pLines2d->Item(2),SolidEdgeConstants::KeypointIndexConstants::igLineEnd,
                              pLines2d->Item(3),SolidEdgeConstants::KeypointIndexConstants::igLineStart,true);
    pRelations2d->AddKeypoint(pLines2d->Item(3),SolidEdgeConstants::KeypointIndexConstants::igLineEnd,
                              pLines2d->Item(4),SolidEdgeConstants::KeypointIndexConstants::igLineStart,true);
    pRelations2d->AddKeypoint(pLines2d->Item(4),SolidEdgeConstants::KeypointIndexConstants::igLineEnd,
                              pLines2d->Item(1),SolidEdgeConstants::KeypointIndexConstants::igLineStart,true);
    pDims=pProfile->Dimensions;
    pDim1=pDims->AddLength(pLines2d->Item(1));
    pDim1->Constraint=VARIANT_TRUE;
    pDim2=pDims->AddDistanceBetweenObjects(pLines2d->Item(1),0.1,0.1,0,VARIANT_FALSE
        ,pLines2d->Item(3),0,0.05,0,VARIANT_FALSE);
    pDim2->Constraint =    VARIANT_TRUE;
    SolidEdgeFramework::VariablesPtr pVars;
    SolidEdgeFramework::variablePtr pVar;
    pVars=pPartDoc->Variables;
    pVars->PutName(pDim1,(_bstr_t)"Length");
    CString Dim2Str;
    Dim2Str=pVars->GetName(pDim2).Detach();
    pVars->Edit((_bstr_t)Dim2Str,(_bstr_t)"Length/2.0");
    pDim1=pVars->Translate((_bstr_t)"Length");
Posted by: assassin 007
Post date: 5/16/2010 7:45:05 PM
