SE File Property API
Hi Jason,
I'm doing a macro at the moment to try and get the guys here to fill in file properties consistantly.
Can your API write to currently open files? ideally I only want to use one set of methods whether the file is open or not.
James
Posted by: James Singleton
Post date: 8/17/2006 4:10:40 AM
RE: SE File Property API
James,
My API is for closed files only. This concept mirrors what Solid Edge has. i.e. SE File Property API.
Posted by: Jason Newell
Post date: 8/21/2006 2:42:23 AM
Hi Jason,
Thanks for the clarification
James
Post date: 9/13/2006 11:01:37 PM
