SE addin
Atleast anyone reply for this
How to create button for solid edge using vb.net and on click of button has to open excel sheet. please reply
Posted by: Shruthi M
Post date: 9/12/2011 11:02:44 PM
RE: SE addin
Shri,
please, since you always give very few or nearly none detailed information on your problems, you may first try to find your answers in the ressources given below:
- Solid Edge Programmer's Guide documents: mu28000.pdf and sesdk.chm
- VB.NET sample Add-In project located in: C:\Program Files\Solid Edge ST3\SDK\Samples\Addins\VB .NET
- Word document: C:\Program Files\Solid Edge ST3\SDK\Samples\Addins\Doc\addin.doc
Then you may ask again telling us what you have already tried and what is not working as it should.
Posted by: Wolfgang Kunert
Post date: 9/12/2011 11:37:16 PM
RE: SE addin
could somebody share or send me the sample Addins and the word document for VB.NET?
i only have ST2 and there are no samples for VB.NET in the SKD directory.
Posted by: Werner Richtsfeld
Post date: 10/4/2011 3:55:21 AM
