SE files in IE
Is it possible to embed the free SE viewer as part of a web page? I have been trying, but everytime my web page loads, I get an IE add-on error while the page is trying to enable the SE viewer.
Posted by: Jun Huang
Post date: 1/11/2007 7:36:21 AM
RE: SE files in IE
I am by no means an expert in this topic but attached is an example for you to try.
Posted by: Jason Newell
Post date: 1/11/2007 7:50:42 AM
RE: SE files in IE
Wow ... that seemed so easy
Can you do the same for the part viewer ???
Cam
Posted by: Cameron Smith
Post date: 1/11/2007 9:20:54 AM
RE: SE files in IE
You can use any ActiveX control in a web page as long as you know it's CLSID.
SEPartX's CLSID = {E03935A5-FBAD-11D0-8AC7-0800362FB302}.
Simply modify the html to reflect the classid and you should be good to go.
i.e.
classid="E03935A5-FBAD-11D0-8AC7-0800362FB302"
Post date: 1/11/2007 9:27:20 AM
RE: SE files in IE
Does this apply to assembly files too? Can someone list the class id's for all SE files or tell me where I might find them?
Posted by: Bill Ledbetter
Post date: 1/16/2007 8:04:03 AM
RE: SE files in IE
Bill,
Solid Edge has 2 viewers, a 3D viewer and a 2D viewer. You can find the CLSID's in the following registry paths.
HKEY_CLASSES_ROOT\SEPARTX.SEpartXCtrl.1\CLSID
HKEY_CLASSES_ROOT\SEDRAFTX.SEDraftXCtrl.1\CLSID
The SEPartX Viewer should view .asm files just fine. Revision Manager also uses these two controls.
Post date: 1/16/2007 8:09:22 AM
RE: SE files in IE
Works perfectly. Much better than dashboard, IMHO.
Post date: 1/16/2007 8:32:03 AM
RE: SE files in IE
Thanks for the tips. I've been thinking about that for ages.
Is there a way to get IE to open a file automatically ??
Cheers
Post date: 1/18/2007 8:32:10 AM
RE: SE files in IE
Remember that I'm not a web guy .
Try this one.
Post date: 1/18/2007 8:49:20 AM
RE: SE files in IE
Perfect Jason. For a non web guy ...
If only I can figure out how to open the file read only ... life would be perfect.
Cheers
Post date: 1/21/2007 11:17:58 AM
