SE2019 SEpartX.ocx....?
Hi everyone,
I'm using SolidEdge2019 and can't find SEpartX.ocx. Only SEpreview.ocx exists. Can anyone tell me where I can find SEpartX.ocx in this version ?
Thanks for all your help
Mrz
4 REPLIES 4
Re: SE2019 SEpartX.ocx....?
@grfdev I believe that those are not installed anymore by default as they are 32 bit code and SE is completely 64 bit.  If I remember correctly, you can install them by installing View&Markup that can be downloaded separately.
Production: SE 2019 MP8, Testing: SE 2020
http://Grundey.blogspot.com
Thanks for the reply, can you tell me where I can download?
Thank you
@grfdev Here is the link for the English version:
https://downloada.industrysoftware.automation.siemens.com/product_download/solid_edge/full_products/...
