SEDraftX on 64 bit machines
I'm trying to automate the capture of an EMF file from a draft file. The code I got uses the SEDraftX control. This works, except on an XP 64 bit machine. I get an error stating that the class is not registered. The SE Viewer is installed an works. Anybody have any ideas what I'm missing?
Thanks in advance
Posted by: Brian Magill
Post date: 9/17/2007 4:29:10 AM
RE: SEDraftX on 64 bit machines
Hey Brian,
Have you tried running regsvr32 SEDraftX.ocx? Other than that, you'll probably have to send an IR to GTAC.
Posted by: Jason Newell
Post date: 9/17/2007 12:14:35 PM
