SEEC Events
I am trying to capture the SaveAs command when logged in to Teamcenter and with a part open.
Only the SEEC_IsPreCPDEventSupported routine is being called and the value of the boolean it gets passed ByRef is False.
What causes the SEEC_BeforeCPDDisplay event to be not supported?
Or am I reading this value incorrectly?
I cannot find any documentation on the three SEECevents.
Re: SEEC Events
you could try it with the
ApplicationEvents.BeforeCommandRun(DetailCommandConstants.DetailFileSaveAs)
event instead of the SEEC events. To check whether you are in teamcenter mode, you could use
 bool tcModeEnabled = false;
SolidEdgeTCE.GetTeamCenterMode(out tcModeEnabled);
 I also noticed that not all methods of the SolidEdgeTCE interface work.
Re: SEEC Events
Thanks, I'll try that. Need to kill the command as well but struggling with that too!
