SEPartX.ocx crashes IE
I'm trying to use the SEPartX.ocx ActiveX control in IE.
I make an ajax request to the server to obtain the following HTML which is then dumped into a place holding 'div':
<object id="SEpartX" classid="CLSID:E03935A5-FBAD-11D0-8AC7-0800362FB302">
<param name="PartFile" value="\\servername\sharedfolder\item.par" >
IE then promptly crashes with the error log:
Problem Event Name: APPCRASH
Application Name: IEXPLORE.EXE
Application Version: 10.0.9200.16611
Application Timestamp: 5191e7aa
Fault Module Name: JtOGL72.dll
Fault Module Version:
Fault Module Timestamp: 49ca3ee4
Exception Code: c0000005
Exception Offset: 0000a253
OS Version: 6.1.7601.
Locale ID: 2057
Additional Information 1: 6791
Additional Information 2: 6791a5c10fa29dd762bb47a4f1b395d0
Additional Information 3: adf3
Additional Information 4: adf37d73b4200a88be088d543214e5cd
Does anyone have any documentation on how to use the SEPartX.ocx control in a web environment?
What other "PARAMS" are available?
I need to dynamically update the path to the part file to display without crashing IE.
Any help or nudges in the right direction would be appreciated.
Posted by: Philip Reed
Post date: 7/3/2013 10:33:41 AM
FYI, this works if I declare the html statically, it only fails if I try to load the HTML dynamically.
I created a JSFiddle to demonstrate the issue here:
(Open with IE)
if you specify a valid path to a local part file in the "PartFile" PARAM, you should be able to recreate the issue by pressing 'Run' at the top of the screen.
Post date: 7/3/2013 10:35:29 AM
