SEv20 Options Projection Angle variable
Hello all,
How can I find out what method / variable / constant that would be controling the SEV20-DRAFT>TOOLS>OPTIONS>DRAWING STANDARDS>PROJECTION ANGLE of "First Angle Projection" or "Third Angle Projection"?
I am not an expert programmer, but I have a strong understanding, I believe.
I thought maybe the Solid Edge Spy application would help, however, it's like hunting for a needle in a hay stack if you are unsure of where to be at.
My goal is to make a macro .exe file that I can execute to toggle this option from one or the other, although, I am just haveing trouble trying to locate the right spot I think.
Thanks for any help,
Big Dan
Posted by: Dan Miller
Post date: 9/23/2010 10:30:02 AM
RE: SEv20 Options Projection Angle variable
Dan,
I looked in Spy and searched the documentation and can't find anything either. I suspect this is something that is just supposed to be set in the template and then left alone. Let me know if you fine anything.
Posted by: Terry Tyson
Post date: 9/24/2010 3:41:39 AM
