SOLID EDGE FILE PROPERTIES
Hello VBA Experts,
I have one excel file with some properties. I need a VBA code to update the active Solid Edge file properties. And it should take all the values from the excel sheet. If I run the VBA code from excel, then only the "ACTIVE SOLID EDGE FILE PROPERTIES" Should Update. BTW I am using SOLID EDGE ST7. Attached file is for your referecne.
Thanks in Advance,
RAY
RAY
