SOLID EDGE ST6 ERROR
while opening solid edge st6 this error msg is showing and while cliking ok the app closes
Re: SOLID EDGE ST6 ERROR
Could you please provide more information?
i.e.:
- What version of windows are you using;
- What type of graphics card you have (have you updated to the latest certified SE drivers?);
- Have you installed the latest ST6 maintenance pack? (latest is MP14 I believe), if not; download the latest maintenance pack from gtac using your siemens webkey: download.industrysoftware.automation.siemens.com
Maarten Elings | Engineer
