ST3 - Handling Save button
Hi All,
I'm trying (or better - I'm looking for a solution now ) to handle "Save" button in SolidEdge ST3.
Every time, when user clicks a "Save" button I want to run a small macro, but i don't know how to handle a save action.
I will be very grateful for any hint!
Small Update: what can I do is a small FileWatcher, which runs a default action, when modification date of my file will be changed (as save signal). But - I won't to do it with an external tool, then a direct integration with SE seems to be an ideal solution.
Piotr
Posted by: Piotr Jedrkowiak
Post date: 4/12/2011 8:37:08 AM
RE: ST3 - Handling Save button
The only solution that I know of with this level of integration is to write a custom addin.
Posted by: Jason Newell
Post date: 4/12/2011 9:03:39 AM
Hmmm... I found something like:
Public Overridable Event AfterDocumentSave As DISEApplicationEvents_AfterDocumentSaveEventHandler
with summary: "This event occurs when a specified document is saved."
It could be helpful.
Post date: 4/12/2011 9:34:50 AM
