ST4 rebuild error
Hello all,
I installed ST4 and tried to rebuild project but I got some errors
'SolidEdgePart.Profile' does not contain a definition for 'Dimensions'
'SolidEdgePart.Profile' does not contain a definition for 'Relations2d'
'SolidEdgePart.Profile' does not contain a definition for 'Lines2d'
'SolidEdgePart.Profile' does not contain a definition for 'ProjectRefPlane'
And they are really not members of the object.
What is wrong?
In older version it worked correctly.
Thanks for any help.
Jara
Posted by: Jara Ctverak
Post date: 4/4/2012 4:43:34 AM
Re: ST4 rebuild error
I see no changes to the Profile API when I look at ProjectRefPlane. Both the ordered and sync Profile APIs contain that method. What does the object browser show you?
Assuming you have all of the Visual Studio tools, you could run "oleview" and open the part.tlb file. There you can find the Profile dispatch interface and look for the same methods/objects in the tool.
I also wonder what intellisense shows you when you type "profile." Does it show the ProjectRefPlane method in the drop down that (eventually) shows up?
Posted by: R.D. Holland
Post date: 4/12/2012 4:27:43 PM
