Reply
ST6 : MinimumDistance Method
I need to display the minimum distance between two feature in my part document :
object element1 = null;
object element2 = null;
SolidEdgePart.EdgebarFeatures edges = part.DesignEdgebarFeatures;
foreach (object obj in edges)
string g = SolidEdgeCommunity.Runtime.InteropServices.ComObject.GetPropertyValue<string>(obj, "Name");
if (g.Equals("element1"))
element1 = obj;
if (g.Equals("element2"))
element2 = obj;
double dis;
Array point1 = new double[3];
Array point2 = new double[3];
part.MinimumDistance(element1, element2, out dis, ref point1, ref point2); -->A first chance exception of type 'System.Runtime.InteropServices.COMException' occurred
Console.WriteLine("Minimum Distance = " + dis);
Can someone help me please ?
How can I get the minimum distance between two elements in my part (ST6 )?
Thanks.
Mahbouba
Re: ST6 : MinimumDistance Method
I didn't try this with a feature object but I think the method needs geometric objects like faces.
JB
VS2015, SE ST10
