ST7 - New Measure Command
Hello All,
I am trying to update my VBA tools for ST7, particularly trying to replace old 'Measure Distance" calls:
.StartCommand(CommandID:=AssemblyAssemblyToolsMeasureDistance)
.StartCommand(CommandID:=WeldmentToolsMeasureDistance)
.StartCommand(CommandID:=PartToolsMeasureDistance)
.StartCommand(CommandID:=DetailToolMeasureDistance)
with a new 'Measure' command but I am having problem finding CommandID or command name for it.
Freshly downloaded Spy does not seem to see it as well
Thanks in addvance for your help.
Milan
www.aaaengineering.com
Milan Wendl, MEngSc, P.Eng.
AAA Engineering, Canada
ST10, SolidWorks Premium 2018
Re: ST7 - New Measure Command - "Solved'
It's me again,
Went to look at it again and Spy shows CommandID for all following environments:
.StartCommand(CommandID:=SheetMetalToolsMeasureDistance)
the same value of 11265.
So it does not need extra assembly, part, sheet metal and weldment code. This wil do for all:
.StartCommand(CommandID:=11265)
Milan
