Same ol' Questions - How do i....
How do I learn to write macros for SE?
Currently i would like a Rev cloud Macro and can not seem to find one. I have no training on writing macros but i have messed around with them and took a class on Lisp writing about 13 years ago. So where do i start? is there a macro out there where i can look at it an try to make it work for my rev cloud?
Thanks for the input
Posted by: Nathan Gardner
Post date: 9/25/2012 6:25:13 PM
Look in Solid Edge help for the Solid Edge Programmers Guide - that's where I started, doing things like displaying and changing file properties.
You will also need to learn vb.net, but you can (if you are careful !!) do that to a great extent as you go along.
Generally you can find a lot of vb.net code and help in the internet.
Posted by: Terry
Post date: 9/26/2012 2:21:06 AM
If you have VS 2010 you can go to file/new project and then click the "on line templates" button on the left of the dialog. Then on the upper right of the dialog you will see a search button. Key in "solid" and wait a second or two.
You should see three templates show up. One of them is a macro template. That can get your started.
Posted by: R.D. Holland
Post date: 9/27/2012 6:35:21 PM
