Save As PDF....All Sheets
I want to save a dft file off as a pdf. I am able to do with with
doc.saveas (PartName & ".pdf").
However It defaults to only printing off the active sheet. I know how to change the options under save as translated but this is going to be running on computers company wide. Is there a way to set this option in VB.Net?
I tried Doc.saveas(PartName & ".pdf", SolidEdgeConstants.PrintRangeConstants.igPrintAll) however this didn't work.
VB.Net 2008, Windows 7, ST3
Posted by: sean tormey
Post date: 4/10/2013 3:17:36 PM
Sean,
Solid Edge keeps some print PDF related parameters in the registry under HKEY_CURRENT_USER:
Setting the value of the key shown below to 1 will achieve what you want.
HKEY_CURRENT_USER\Software\Unigraphics Solutions\Solid Edge\Version 105\Global\PDF_PRINT_ALL_SHEETS
Posted by: Wolfgang Kunert
Post date: 4/11/2013 4:23:03 AM
//objApp is the SE session object
// dftfile is the location of SE draft on the local drive.
// Target is the name of the local destination of the PDF File.
Dim rootdft As SolidEdgeDraft.DraftDocument = objApp.Documents.Open(dft_file)
rootdft.SaveAs(target)
Posted by: Jacob Andrews
Post date: 5/7/2013 12:54:30 AM
