Save Hole Default Registry without Restart
Hello Edgers:
I have a question regarding the 'Save as default' button in the Hole Options dialog which saves the values in the registry under:
"Software\Unigraphics Solutions\Solid Edge\Version 108\PrefSets\Hole"
When I change these registry values programatically from my application, Solid Edge does not read them until I restart SE.
The 'Save as Default' button in the Hole Options dialog however does not have this restriction and saves+reads back the values immediately i.e. without a SE restart.
Has anyone worked on this before or has an idea on how to force Solid Edge to read the registry changes for the Hole default values without a restart?
