Save a Assembly file as Igs but only Displayed Part
Is there any way to save the assembly as Igs but only the displayed part using C#
There is a way to do this manual by selecting the option while exporting.
Re: Save a Assembly file as Igs but only Displayed Part
Hi @Dev13,
I think that once you change the options, they are persistent. So if you save the part using C#, it should save only what is displayed.
Héctor Pelayo Izquierdo
Engineering Department, JAE Ingeniería y Desarrollos, S.L.
Solid Edge ST9 MP5 | NX 9
Development: VB.NET
in that case i need to relie on the last setting of Solid Edge while exporting igs.
i wanted to know is there any other way by which i can make sure only displayed parts will be exported.
there is SaveAsJt option while programming (document.SaveAsJt)in that we can set export only visibile part by passing argument. But i am not able to saveasJT also. It is saving all parts.
