Save an assembly in revision manager
Hello Everyone,
I have an assembly_1 with two parts, with name part_1, and part_2. And there is a relation between this two parts. I want to saveas the assembly etc: assembly_2 and the two parts with name part_3 and part_4.
I can save them, and can change the links in the assembly from part_1 and part_2 to part_3 and part_4 but it losts the relation between the two parts.
I use the revisionmanager.insight and revdocument.saveallink() commands, but it doesn't work.
Here is the code I use
try
revapplication = new RevisionManager.Application();
insight = revapplication.Insight;
insight.CopyFiles(osszeallitasinev, part1_nev, part1_nevuj);
insight.CopyFiles(osszeallitasinev, part2_nev, part2_nevuj);
revdocument = (RevisionManager.Document)revapplication.Open(osszeallitasinev);
linkeddocuments = revdocument.LinkedDocuments;
linkeddocument = linkeddocuments.get_Item(1);
linkeddocument.SetPath(part1_nevuj);
revdocument.SaveAllLinks();
linkeddocument = linkeddocuments.get_Item(2);
linkeddocument.SetPath(part2_nevuj);
insight.CopyFiles(osszeallitasinev, osszeallitasinev, osszeallitasinevuj);
revapplication.Quit();
catch
Please help with some info.
Posted by: Ungi Laszlo
Post date: 2/15/2012 3:30:31 PM
Re: Save an assembly in revision manager
Maybe it is not too clear, that what I want to do.
I want to use the revision manager set action to copy, and perform actions programs in my program.
Thanks.
Post date: 2/16/2012 2:29:20 AM
