Save assembly
hey guys!
it's me again Smiley Happy I have a following problem:
My program opens an assembly file and updates it, basically it makes visible or invisible occurences and suboccurences, writes variable values in variable table and so on. After that I want to save file and close it.
when I use standart objDoc.Save() it doesnt save the occurences that I made visible or invisible before. I can only make it happen when click the "Save" Button in Solid Edge. I checked it in SES Spy Event to see the difference between Save() Method and actual Save button in SE.
Save() Method:
AfterCommandRun theCommandID (AssemblyCommandConstants.AssemblyAssemblyToolSelect)
BeforeDocumenSave theDocument (NameOfTheDocument.asm)
AfterDocumentSave theDocument (NameOfTheDocument.asm)
BeforeCommandRun theCommandID (AssemblyCommandConstants.AssemblyAssemblyToolSelect)
Save Button:
BeforeCommandRun theCommandID (AssemblyCommandConstants.AssemblyFileSave)
AfterCommandRun theCommandID (AssemblyCommandConstants.AssemblyFileSave)
Any Ideas how I can program that? I tried to do that over API functions but can not find the one for assemblyfilesave...
I am using Visual Studio 2010 and VB.NET
Any help is highly appreciated..
Regards, salwadora
Posted by: Salwadora
Post date: 2/26/2013 3:17:41 AM
Save assembly
No one knows what I can do about it?
Post date: 2/27/2013 5:44:38 AM
Save assembly
Post date: 2/27/2013 5:44:46 AM
Save assembly
Hey guys, I found the solution and just wanted to share it here if someone else has the same problem at some point.
Well, I ran my programm in the background setting seApplication.Visible to False. As soon as I changed it to True before saving the document, it worked properly.
Regards, salwadora
Post date: 2/28/2013 10:40:45 AM
