Save current orientation as a view
i want to save the current view orientation as named view. So How to access the View --> Save current view in part modelling environment through VB. thanks, balaji.L
Re: Save current orientation as a view
Please check out the example in the online help for the SaveCurrentView() method of the View object.
This shows all calls you have to make to save the current view orientation as a named view!
Thanks martin, But i am using Solidedge ST4. Savecurrentview() method is not available.
