Save draft as PDF with a 3D PDF page
Is there a way to save a draft file to PDF with a 3D PDF as one of the pages? I can save the draft to a PDF file and I can save a 3D PDF from the model, but I'd like to make a PDF that contains both the draft and a 3D PDF view all in the same file.
Terry Tyson
Software Automation Designer
3 REPLIES 3
Re: Save draft as PDF with a 3D PDF page
Before trying to find a solution through API, I would like to know how to do this interactively?
I was unable to do it manually and therefore don't know where to start looking for some source code...
Just submitted IR# 6991292 requesting this functionality.
Terry Tyson
Think you need to generate both files and then use a dll to merge those files, pdfsharp should be ok.
Romuald BERTIN
