SaveAsImage from the scene of ERA
Hi
I need save a image from a scene from ERA(Explode-Render-Animate).
My code is:
Dim objApp As SolidEdgeFramework.Application
Dim objAssDoc As SolidEdgeAssembly.AssemblyDocument
Dim objView As SolidEdgeFramework.View
objApp = GetObject(, "SolidEdge.Application")
objAssDoc = objApp.ActiveDocument
objView = objApp.Windows.Item(1).View
objView.SaveAsImage(path & name & ".jpg", 0, 0, 0, 0, 0, SolidEdgeFramework.SeImageQualityType.seImageQualityHigh, False)
But the file JPG doesn't contain the lighting and background colors that was set on Render Setup.
Can you help me?
thaaanx
Posted by: jose
Post date: 2/28/2012 12:01:46 PM
