Saving as 3D PDF
Hi !
I'm trying to generate a 3d PDF for ASM, PAR and DFT files.. I use the SaveAS() method :
docs.Open(mdoc.FullName)
mdoc.SaveAs(s3DPathName, , True)
mdoc.Save()
mdoc.Close()
In case of Draft documents my code parse all the parts and assemblies included in it, open each one and save it.
Now with drafts that contains a lot of documents, the treatment is too long and Solid Edge is blocked!
Any idea to fix this problem ? a way to save documents without opening them for example?
Thanks for any help.
Tamer
Posted by: Tamer EL BAKKALI
Post date: 4/19/2012 12:48:41 PM
Re: Saving as 3D PDF
To SaveAs as doc without opening it:
Dim oApp As SolidEdgeFramework.Application = Marshal.GetActiveObject("SolidEdge.Application")
Dim oDoc As SolidEdgePart.PartDocument = GetObject("D:\\Temp\\Body01.par")
oDoc.SaveAs("D:\\Temp\\Body01.pdf")
oDoc.Close()
~Tushar Suradkar
www.CADVertex.com
For me the call
document.SaveAs("test.pdf", Type.Missing, true));
doesn't produce a 3D PDF.
See: http://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/How-to-SaveAs-3D-PDF/m-p/3...
I too am not getting the 3D PDF using SaveAs.
This query was regarding saving a document without actually opening it which I replied to.
I am too watching your other question closely to know how to create a 3D PDF after having investigated it for some time without success.
~Tushar
