Select all occurrence from selected assembly
I want to selct all occurrences that are in a selected subassembly, but only the parts and sheet metal parts. Also I want to select the parts en sheet metal parts wich are in a subassembly of the selected assembly (for all levels).
It means the following:
Topasm
   Subasm
      Par
      Psm
      Subasm2
         Par1
         Par2
When opening Topasm select the Subasm. Then run the macro wich select Par,Psm and Par1,Par2.
I use this to assign file properties to all that parts.
Any body an idea how to do this in VB.NET?
Posted by: marthijn van Leeuwen
Post date: 11/14/2011 8:47:09 PM
